Apperance Gallery not working!!
ptc-6785938
1-Newbie
I don't know how to get colors in creo parametric MO10. This is the education model and I cannnot edit color in the appearance gallery.
1 ACCEPTED SOLUTION
Ok, let's try second option:
1. Select PTC Creo Parametric 3.0 shortcut icon on desktop > Right Click and select properties
2. Move the cursor at the end in Target path > Add a empty space followed by -g:win32_gdi
3. Apply and close
8 REPLIES 8
Christina,
This seems to be due to graphics.
Add config option graphics win32_gdi in config file and test this.
How exactly do I do this? I am new to this program
1. Open config.pro in text editor from install location of Creo 3.0 (default is C:\Program files\PTC\Creo 3.0\M010\common files\text\)
2. Add graphics win32_gdi > Save and close the file
3. Launch Creo 3.0 and test.
I am in there in the folder but where do I get config file and how do I add it in. Is it already somwhere in my computer. How do I create a new text editor?
Also I can't even open config.pro. I have windows and says it can't open unless I use other installed programs. Should I open with creo parametric.
3. Apply and close
StephenW
23-Emerald II
(To:ptc-6785938)
Open the config.pro file using a text editor like NOTEPAD
At the bottom of the list of options, just copy and paste in the following:
graphics win32_gdi
save the file, exit and restart Creo
Yea it works!! Thanks so much.
