Make it possible to change the default dtl line command of default_bom_balloon_type line from simple_circle to 'bom_balloon_1' for example to enable the assembly balloons to be shown correctly on new drawings.
Current workaround is to include the symbol somewhere on the drawing template and then this option will work as opposed to pointing to a symbol library.
Hello Andrew,
A very good tip ! Thanks a lot.
The only little problem remaining is that a symbol with just the model_name (no geometry) is not automatically adjust with the syze of the name.
It's not too bad for us because all parts should have the same size name.
I think PTC should support a bom balloon type "model_name" with an automatic size changing with the part name size.--> idea 4287
Thanks again. Fabrice.
