Arbitrary part names with STEP-export
ptc-5043118
Does anyone know if it is possible during a STEP-export to automatically change the original part- and assembly names to something arbitrary like a series of numbers instead?
Dale_Rosema
(To:ptc-5043118)
You can change the file name to anything you like, but you first have to select the step extension and then change the file name. (Manually)
Dale_Rosema
(To:Dale_Rosema)
You can vote on this product suggestion if you would like to be able to change the name, and then select the step file extension:
http://communities.ptc.com/ideas/2258
Thanks, Dale
Thanks for the reply!
Maybe I was not totally clear in my description - what I am looking for is when someone opens the STEP-file the names in the model tree should be something arbitrary like AB01, AB02, AB03...
Dale_Rosema
(To:ptc-5043118)
From searching the archieves, here is something about a batch import of step files. You may be able to use the same concept for exporting the files. But I think that the answer may be that this is not doable.
http://communities.ptc.com/message/201422#201422
