How to change the default ballon arrow style in Creo 2.0 drawing and also how to change the baloon diameter .
After So Much Search i just got how to change the Default baloon diameter here,
File > Prepare > Drawing Properties > Miscellaneous Options > max_balloon_radius
min_balloon_radius
Hello!
You can't change directly ballon diameter. But you can change the default ballon symbon in the directory
Creo 2.0\Common Files\M080\symbols\report\bomballoon
Arrows you can change them while you are putting the ballons
min_balloon_radius
