Assembly Cut and the Damage Done
SOLVED
Level 10
Hi all!
Please see attached.
Read notes in PDF.
Anyone ever deal with this?
This is not isolated to just this case. It can be duplicated from scratch.
Wayne
Re: Assembly Cut and the Damage Done
I attached video showing appropriate steps ...
Attention!!! Part mass properties are fixed for ever, any geometry modification does not cause a change in weight.
Martin Hanák
21 REPLIES 21
Don't add any columns to your family table that will change based on the effects of the assembly level cut (like calculated mass.)
Realize that assembly cuts create "hidden" family tables out of the affected components which means for the purposes of the repeat region these are unique models with different masses.
Overall, if you mean for that cut to exist in the actual part rather than only in the context of the assembly, then I would avoid using an assembly cut. Assembly cuts only affect the particular component placement that it directly cuts. You can use the options in the cut to have it affect that actual part and then in your example they both would have the hole but in general that's where I'd try to avoid the assembly cut to begin with.
This is in fact a solution. However, our standards call for the use of these at the moment. Thanks.
One thought I had was to somehow make the one part weight = to the others via a relation. I am not sure how to write that?
Yeah. I was actually helping someone out with this. I have never had this situation. This is news to me. Thanks.
I am helping someone out with this. For whatever reason, they have the need to machine in the finished assembly. I do agree assembly features in general come with issues. Thanks.
@wfalco wrote:
Hi all!
Read notes in PDF.
Wayne
in part properties you can change the method how its weight (and other properties) is obtained. By default weight is calculated by Creo (in this case your two components have different weight). You can set part mass properties to fully assigned, this means that you assign fixed value to mass parameter (in this case both components have the same weight and in repeat region they "fall" into the same row).
Martin Hanák
Sounds interesting. I am not sure how to do this. I can send you my little sample drawing if that helps?
No problem, send it.
Martin Hanák
