Also in assembly 10 instance with X height & SKELETON changing dimension.
So , how to co-relate each individual assembly instance with the different skeleton ?
When I'm trying to do it by adding component option into family table , then skeleton going to change but according to part will not be generated ....& assembly fail....according to required dimension.
Waiting for expert suggestion, if any one have idea.
In addition to above , if any one cheked in assembly mode , another assembly instance can govern through the family table , by component option.\\
Assembly prepares by a use of top down approach skeleton model...........
Only problem in assembly , skeleton going to change through family table but , according to it part (extrude) will not generate........
