Auto Weight in Bom
SANTOSHKAPLAPUR
1-Newbie
Auto Weight in Bom
I was successfully able to bring weight in bom,but the weight is showing in three decimal units how do i change it into single digit
1 ACCEPTED SOLUTION
if table cell shows value saved in weight parameter (for example), then you can use &weight[.1] notation inside table cell.
MH
Martin Hanák
2 REPLIES 2
MH
Martin Hanák
That worked ,thank you so much
