I want to customize the one of the frame cells up to document type in drawing. I've looked up a parameter for subtype but I couldn't find. Changing of title isn't very important, I can define as "Dimensions" for all of them.
If document type is Assembly then:
Title: Dimensions, Value: blank or "---"
If document type is sheetmetal then:
Title: Unbend Dimension Value: Unbended bounding box
If document type is part then:
Title: Dimensions Value: Bounding box
Best regards,
