Autocad Conversion
SANTOSHKAPLAPUR
Autocad Conversion
Whenever i convert the creo drawing into Autocad the text style and dimensions style changes and notes which i have writtne in drawing they also change and some times they go out from the template boundry , then i have to manually change those all things which is really annoying and lot of waste of time
Is their any way so that when i convert DRW into DWG their shouldn't be any change in dim style or text style.
and one more thing what is the standard procedure to convert the DRW into DWG?
1 ACCEPTED SOLUTION
Hello again.
I did some tests now and it worked. The procedure is:
1-Export DRW to DWG
2-Open a DWG file where you have the dimensions style that you like
3-In menu Format - Dimensions , set the dimension style you want as current or predefined
4-Insert the DWG file that you exported into the file you have open before
5-In dimensions Menu there is a Update all dimensions Icon, select it and then do a window to pick all drawing
That's it
Hello!
You can insert your DWG file into a template of your Autocad with the correct dimensions then i think there is a command in Autocad to update all the dimensions and anotations into your template style
Hi ,
Thank You For Your attention can you explain me how exactly to do in autocad i amen i really not good in autocad
Hello again.
1-Export DRW to DWG
That's it
