Automatic drafter name
Highlighted
Aquamarine
I'im wondering if it would be possible to automaticaly assign the drafter name of a part to a parameter ? Based on the mac adress or the host id for example.
Is it possible to retrieve one of these two values within Creo Parametric ?
Highlighted
Re: Automatic drafter name
I am almost sure it is possible to create AutoIt script/batch file which fetches MAC address/machine name/user name. If you have it ready, you can create Creo mapkey which runs the script and puts the value into part's parameter.
Martin Hanák
Highlighted
Thanks Martin for you reply. I used AutoIt long time ago for personal use. I should have a look at it for this particular task. It might also give me other ideas.
