Does it possible to export the Bill of Material of an assembly into an Excel file instead of HTML? P.S.: My ProE version is WF2.0 Thanks to all This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Try Config option: info_output_format (set to text) then save the file as a text file. Then you can open using Excel and set columns as "Fixed Width". It's not perfect, but it gets it into something you can work with.
