I have a BOM table exploded the all sub-components. I can reach all component's name and parameters. However I couldn't reach top level information.
Is there any way to add name or its parameter of top level assembly?
Please see the attached picture for the sample.
Thanks in advance!
I know I'm digging out an old topic but it turned out I'll need something similar to this for the ERP system we're implementing, so I was wondering if someone found out how to solve this problem. I need the file name of the assembly that the part/sub-assembly belongs to. &asm.name only gives the file name of the top level assembly which doesn't help.
I think requested functionality is not available. You have to get information manually, for example:
Below you can see an example of assembly structure
Assembly 00_KOMPLET contains:
1 Sub-Assembly 01_SKRIN
1 Sub-Assembly 02_PAKA
1 Sub-Assembly 03_PIST
1 Part MH_PODSTAVA
Sub-Assembly 01_SKRIN contains:
1 Part I_PLYWOOD_BACK
4 Part J_CORNER_SUPPORT
2 Part I_PLYWOOD_SIDE
3 Part H_FRONT_BRACE
1 Part K_DOOR
1 Part MH_DNO
1 Part F_LEVER_FULCRUM
2 Part MH_PODSTAVA
Sub-Assembly 02_PAKA contains:
1 Part A_HANDLE
2 Part B_LEVER
Sub-Assembly 03_PIST contains:
1 Part D_COMPRESSOR_PAD
1 Part C_COMPRESSOR_ARM
2 Part E_COMPRESSOR_PAD_SUPPORT
