BOM not merging part quantities.
Garrett317
8-Gravel
I have two parts (call them Part 1 and Part 2) within my BOM that are used in two different positions in the assembly. My BOM calls out Part 1 and Part 2 twice:
QTY       PART
1            Part 1
1            Part 1
1            Part 2
1            Part 2
How can I merge the rows together so that there is one row for Part 1 and another for Part 2, each having a quantity of 2?
QTY       PART
2            Part 1
2            Part 2
Could this be fixed using the repeat region?
StephenW
(To:Garrett317)
Go to table - repeat region - attributes and select No dup/level.
If you are using flexible components, these have historically been a problem for repeat regions.
StephenW
(To:Garrett317)
Thank you, that worked great. However, the index numbers changed. It used to be:
INDEX     QTY     PART
   1              1        Part 1
   2              1       Part 1
   3              1       Part 2
   4              1       Part 2
After merge:
INDEX     QTY     PART
   5              2        Part 1
   6              2       Part 2
How do I change the index values to:
INDEX     QTY     PART
   1              2        Part 1
   2              2       Part 2
StephenW
(To:Garrett317)
Had you already used fix index? If so, you'll need to unfix 1-4 or maybe unfix the region, depending on how you fixed the index.
