Hi all, using Creo 7 here.
I'm trying to set up some drawing borders formats using tables.
I don't want to merge the cells.
No matter what i do i cant blank a table line.
I've selected the whole table - line display - blank - select line....but doesnt blank it
any ideas?
thanks
The line display command will only let you blank lines that are internal to the table. It doesn't let you blank the outer edges or lines that make up the "border" of a table. Are you trying to blank those types of lines?
Thanks for the replies.
I've worked out what the problem was.
I had put a 1 cell table around the edges of the sheet to create a border.
Then i made a multi-cell table inside that on the sheet to start making the title block.
It wouldnt let me blank lines or add rows/columns with that table on the sheet.
I had to move that table off the sheet to the side - then i could modify it.
Hope that makes sense.
