Bom Repeat Index in a Note
SOLVED
Highlighted
Alexandrite
All,
Not sure if it's do-able. Can I make a note that reads:
1. Remove burrs from f/n (item) 3.
And have the "3" report from the bom?
From what I've been reading the answer is or was NO?
Hopefully I am explaining properly?
Creo 4.
WayneF
Tags (2)
1 ACCEPTED SOLUTION
Highlighted
Re: Bom Repeat Index in a Note
In this duplicate idea, @mender explains that there is a certain amount of difficulty in doing this within the software
 https://community.ptc.com/t5/Creo-Parametric-Ideas/Repeat-index-parameter-value-as-by-rpt-index-for...
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Highlighted
I don't believe you can use repeat region parameters (rpt.index) outside of the table and balloons.
It sure would be nice and...
https://community.ptc.com/t5/Creo-Parametric-Ideas/Refer-to-rpt-index-in-a-note-or-symbol/idi-p/4622...
Steve Williams
Highlighted
Steve Williams
