Broken View Spline Extended
Alexandrite
Creo 6 or probably does not matter.
Using Broken View: Is it possible to extend splines per pic 2? Pic 1 is default.
Wayne
Re: Broken View Spline Extended
Not without adding something to the model so it "extends" past the edges. The break only goes to the extent of the model.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
