CAN YOU RELATE A BMP OR JPEG OBJECT TO A VIEW
BriGuy
11-Garnet
I have a bitmap that I inserted into a drawing.  Is there a way to relate it to a view so the image object moves along with the view?
Using Creo 2.0 M190
1.] only drafted drawing entities can be related to a view
2.] you can add picture into model, unfortunatelly this picture is visible in drawing only in case that view display is set to shaded
Martin Hanák
Martin Hanák
Thank Martin.  That is what I figured.
