CAN YOU RELATE A BMP OR JPEG OBJECT TO A VIEW
SOLVED
Garnet
I have a bitmap that I inserted into a drawing.  Is there a way to relate it to a view so the image object moves along with the view?
Using Creo 2.0 M190
1 ACCEPTED SOLUTION
Re: CAN YOU RELATE A BMP OR JPEG OBJECT TO A VIEW
1.] only drafted drawing entities can be related to a view
2.] you can add picture into model, unfortunatelly this picture is visible in drawing only in case that view display is set to shaded
Martin Hanák
2 REPLIES 2
Martin Hanák
Highlighted
Thank Martin.  That is what I figured.
