I have a bitmap that I inserted into a drawing. Is there a way to relate it to a view so the image object moves along with the view?
Using Creo 2.0 M190
1.] only drafted drawing entities can be related to a view
2.] you can add picture into model, unfortunatelly this picture is visible in drawing only in case that view display is set to shaded
Thank Martin. That is what I figured.
