CREO 2.0 M100 TOL_MODE CONFIG??
timhelgren
I am trying to make it so I have my tolerance option in my config file set to yes, but when I do this all my dimensions show with limits. I would like to change that setting to NOMINAL so I don't have to edit every dimension just to show one tolerance. I checked my config options and saw there was a tol_mode setting with the little red NO circle (this was set to limits). I am assuming that the option was not functioning properly, so I deleted the option and it will not allow me to add it back in to my config settings. I did some more checking and tried to add the setting to my drawing properties menu to no avail. Did PTC get rid of this option so now i "get" to edit every dimension value so I can show the one tolerance that I was shooting for?
Tim
STEVEG
(To:timhelgren)
Yes. It was deleted in Creo 1. It's listed in the config options doc for WF5 but not C1. Not sure if they replaced it with something else.
Steve G
Creo 2.0, M100
Open a drawing and go to File, Prepare, Drawing Options, Change - in the dimensions area you will find this option that would save in your drawing .dtl file - it affects newly created dimensions, not sure about Shown ones
[cid:image001.png@01CF915C.29162690]
Hope this helps
Mike Brattoli
Moen Incorporated
Global Product Development Process Management
Administrator - PLM
[Description: Description: New Moen Logo.tif]
[Description: Description: Description: Description: Description: Description: Description: Description: fb]<">http://www.facebook.com/moen> [Description: Description: Description: Description: Description: Description: Description: Description: Description: t_logo-a.png] <">http://www.twitter.com/moen> [Description: Description: Description: Description: Description: Description: Description: Description: YouTube] <">http://www.youtube.com/moenfaucets> [Description: Description: Description: Description: Description: Description:
Thanks for all your responses! I had our chief engineer change our start part to include the default_tolerance_mode so we don't have to fuss with it on any new parts from here on out.
Tim Helgren
Drafter
Specialty Products
