CREO2 - MOVE DIM
EricHuffman
2-Guest
CREO2 - MOVE DIM
Gurus,
I couldn't find this in the help...how do you move a dimension from one hole to another when there are in a pattern?
In Wildfire4 I would erase dim and show by selecting the hole. That doesn't appear to work here.
CREO 2.0 m040
Windchill 10.0 m030
Eric
I find the answer 5 seconds after sending this.
The answer is to DELETE the dimension from the Annotation tree then show by selecting the hole.
Eric
Can't you simply RMB and click "Edit Attach"? Or is that another
"feature" they've added in Creo?
It's one of those stupid features of Pro/E & Creo that have been there forever. If you have a pattern, and you show the dims, the dim will always show up on the second feature of the pattern. You have to do like Eric said and actually show it by selecting the hole. Move attach will not work.
Obviously, move attach would be the logical way to do this. But for some reason, PTC hasn't seen fit to fix this.
David Haigh
