CREO2 Printing
EricHuffman
2-Guest
CREO2 Printing
Gurus,
In Wildfire4 I customized the print config files and they worked perfect. Now, for CREO2, I am using the same pcf's and pnt's that I used in wildfire4 but the colors are all messed up.
Printing black and white works fine but when printing a color drawing the shaded image looks fine but the text is yellow instead of black. See images below.
Are there a new settings for printing? If you are printing fine can you send me your pnt and pcf so I can compare to mine.
CREO 2.0 m040
Windchill 10.0 m030
Eric
Wildfire 4 Drawing
CREO2 Drawing
0 REPLIES 0
