Can not access Dimension properties
SOLVED
Participant
Hi
Could somone please clarify as to how I can access the dimension properties.
As I first go to switch realtions, and the click on the dimension, and then right click, there should be option there to access dimensions properties for me to change the parameter name but there is no option
please can someone help me ?!
Note the the dimension change is in a prt.file
Re: Can not access Dimension properties
  • open part
  • double-click part geometry ... dimesions related to selected piece of geometry appear
  • select dimension, press RMB and use Properties command from context menu
Do not open Relations dialog box !!!
Martin Hanák
7 REPLIES 7
Is the .prt file locked (as in PDMLink/Windchill)? (most common problem I have seen)
When you right click, are you getting any right click menu or just no "properties" option? New users sometimes don't realize you have to click and hold right mouse button longer than other programs. Not sure if that applies to you.
Stephen Williams
Pro/E Version 15/16 (Circa 1995/1996)
I don't know if the file is locked but when I hold right mouse button, the only options I am getting are
-Pick from list
-Lock
-Value
-Move
-Move Text
-Exit Edit Dimension
-Pick from list
-Lock
-Value
-Move
-Move Text
Tags (1)
You can't edit the dimension properties while you're editing the value on screen.  Try picking "Exit Edit Dimension", then left click the dimension once, then right click and see if you can get to properties.
Tried that still no luck, It does show other options but no Diemensions Properties
Should be just as simple as right click, properties in either the drawing or the part file.
If you are in windchill pdmllink, make sure your part file isn't locked, you can't edit model dimensions (even in a drawing) when the part is locked.
Stephen Williams
  • open part
Martin Hanák
