Can we get part name just beside Balloon in creo drawing
cmachakanoor
I have some requirement. I want to get part name just beside Balloon in creo drawing automatically. Currently I am putting it manually.
Is there a way to get it automatically.
Attached snapshot for better understanding.
StephenW
(To:cmachakanoor)
Assuming you are talking about BOM Table balloons, I believe so. You will need to customize your BOM balloon to show a part number parameter (or file name if it is your part number). There is some good info in the post below.
BOM BALLOONS WITH JUST PART NAME - NO GEOMETRY
mender
6-Contributor
(To:cmachakanoor)
If the note has a fixed offset to the circle, then it can be done with a custom bom balloon.  The picture shows the note sometimes left/right/above/below the balloon, which doesn't have a clear means to define it without having two objects (as you are doing currently).
Chris3
20-Turquoise
(To:mender)
For the case shown, you could just have multiple symbols and then do an ALT symbol for those cases in which you need it in an alternate orientation.
