I have an E size drawing format that I would like to use for an A size drawing.
I would prefer not building the A size format from scratch; I am wondering if there is a way to scale the title block tables in different size drawings?
When I bring the E size title block into the A size drawing it wipes out half of the drawing.
Yes you can! Here is the process:
Not that I've ever seen.
I patterned ours after the ASME specs where the A through C title block cells are one size and D through F are a different size. It's significant enough to notice the difference, though a-size still leaves virtually no room for drawing views.
Thank you Tom; we will give this a try.
If this doesn't hold together we probably do as Don suggested and make 2 separate sizes
We just tried this out and this worked just the way you described.
Thanks for your help!
