I am using WF4 M150 and have an issue (nothing new just this time I thought I would inquire) where I would like to apply the use of the real tolerances on a dimension, but the dimension is part of a family table and therefore the display is with the Dimension Name (using @S to replace the dimension value with its name). When you change the Dimension to @S to show the name the visiblity of the Tolerance goes away. Does anyone know if there is a way to show the tolerance when the name is used for display?
Thanks in advance for any assistance.
Chris
Hi, Chris Mckee
You can add different tolerance for each instance as shown my attachment. I think your problem solved.
Anbarasu G
