Chamfer dimesioning & tolerancing
JohnK55
Is it possible to add a tolerance to both the chamfer & angle in a single dimension, see attached screen grab. It's not something I've needed to do before
kdirth
20-Turquoise
(To:JohnK55)
Show both dimensions on drawing and set tolerance for each.  Click outside the view to deselect everything.  Hover the mouse over the angle dimension to determine it's name (e.g. d13).  Select the distance dimension and add the angel dimension to the dimension text (e.g  X &d13).  Lastly, erase the original angle dimension.
kdirth
20-Turquoise
(To:JohnK55)
