Chamfer problem
jdriscol
Chamfer problem
Hey Suganthan,
Is it a true cylinder and not the end of a curve? The tube end surface needs
to be square to thetube to dimension toit.
jd
ps buddy..., Are you doing one of those jobs that used to be done in America?
love your desktop...
Laura Woodward
Senior Mechanical Engineer
Saab Training, LLC
Orlando, FL
(407) 281-3012
Try creating revolved cut instead of chamfer. It also gives you more control.
Jurij Škraba
Research & Developement Department for Hydromechanical Equipment
Litostroj Power | Production of Power Generation and Industrial Equipment |
A revolve won't work in his situation, the chamfer is not on a plane perpendicular to the cylinder's axis. A variable section sweep might be a better choice and would easily do the job.
Doug Schaefer
LinkedIn
