Change Color of SubComponents
Participant
Has anyone figured out a way to change the color of subcomponents within components at a higher level assembly.
Basically I need to change the display colors of certain components that are contain in assemblies that are at the level of a higher assembly. Unfortunately I can't change the components at the lower assemblies or the components themselves because they are released models. Also I only need this special color scheme at this higher level assembly.
I found you can change the color of the entire assembly that is at the level of the top assembly but I can't find a way to click any lower.
Thanks!
Along with Corey's request, can I tag the question of how to change the
color of the surfaces of a upper level assembly cut?
