Change paper size A3 to A1/A0
shansen
1-Newbie
I have done a template with drawing frame in a A3 format, then I saved a copy to create a A1 drawing template but the printing arena is still a A3. I can see in the lower position of the screen it says SIZE: A3. When I double click at it pop up with a box where I can choose Define and after that I can select : Grid Outline, Grid Origin, Columns, Rows and Done/Return. Am I out on a wrong road?
4 REPLIES 4
what extension does have the file containing your "template" ... is it .drw or .frm ? Can you upload the file (How to upload Creo (or other) files) ?
Martin Hanak
Martin Hanák
Hi Martin
I did it another way. I have created a new blank A1 an then used copy / paste from the old drawing.
Søren
TomU
(To:shansen)
Drawings (and templates) can have different size formats applied to them, but I do not believe you can change the size of a format itself after it has been created.
dhermosillo
(To:shansen)
I made a product idea for this since I run into it every time I need to make a new format:
https://community.ptc.com/t5/Creo-Ideas/Allow-format-size-and-origin-to-be-modified/idi-p/498975
