Change relations in multiple parts
rmuller
6-Contributor
Hello guys,
I came into a situation when I need to change relations of multiple parts. I would like to be able to do it at once sice it is a lots of parts.
I just want to add this line: WEIGHT=pro_mp_mass to all parts so I can have weight shown on BOM table file in a drawing.
For next parts I create I will have modified the template files so it will always be there since now on.
Is there a way of doing it?
Thank you for your help.
Radek.
1 ACCEPTED SOLUTION
click asm... > mbr... > User Defined and enter pro_mp_mass
The cell will contains &asm.mbr.pro_mp_mass callout.
MH
Martin Hanák
4 REPLIES 4
you can use pro_mp_mass in BOM table, therefore you don't need to add a relation into your models.
MH
Martin Hanák
rmuller
6-Contributor
(To:MartinHanak)
Hi Martin,
that would be great. I am having problem finding this option. When I add column and a repeat region in it I double click and get this menu:Repeat region.JPG
I can not find it anywhere among those options.. Would you know where is it to be found?
Thank you.
MH
Martin Hanák
rmuller
6-Contributor
(To:MartinHanak)
Great, many thanks Martin!
