Change the display size of labels/text in main window?
Highlighted
Newbie
I've looked everywhere but haven't been able to find what controls the size of how text is displayed for things like datum labels,sketcher dimension, constraints, etc.
I changed it to the stroke font to make it a little less obtrusive but I'd like it to be smaller.
Anyone know how to do this?
Thanks.
Highlighted
Re: Change the display size of labels/text in main window?
the hidden config option text_height_factor works, larger ratios give smaller font size, and will change the font size of datum tags, dimensions, etc. when modeling and in sketcher
Datum Tag Size In Model Display?
Creo 2.0 drawing dimension font size
Sketcher Dimensions - PTC: Creo Parametric (Pro/ENGINEER) - Eng-Tips
WF2.0 text size - Page 2 - MCAD Central
A Pro/ENGINEER tip for Model Text - Synthesis Engineering Services, Inc.
