Changing dimension values/Adding text
Regular Member
(Creo 1.0) I have a drawing file with (at this point) 4 different models. My drawing is dimensioned and laid out how I need it. My question is, how do I add simple notes to a dimension? Basically I just want to add "MAX. O.C." to the end of the dimension value. Does it need to be a certain type of dimension?
Thanks in advance.
Re: Changing dimension values/Adding text
Ha, don't know how I missed that huge white box in the dimension properties. =X
It literally took you 4 minutes to solve your own issue. Isn't that always the way it goes? You look around for a solution and can't find it. Then, finally, you break down to ask for help from the rest of the world. The moment you hit the "send" button, the solution presents itself.
Ah, the number of times that's happened to me.
