Color and Appearance Editor
STEVEG
WF4 M140 and M150
I go into the color editor and select the From Model button. After I select a colored surface from my model then the options toselect the type (part, surface, etc.), Clear, andApply buttons all are grayed out. The only way to fix it is to close the editor and open it back up. Has anyone else run into this?
Steve G
STEVEG
(To:STEVEG)
Thank you Christopher. All you have to do is "unclick" the From Model button. Who knew.
Steve G
