Hi all,
When making a cut solidify, EMX seems to be able to to transfer colors from the parent quilt to the child surfaces:
http://support.ptc.com/appserver/wcms/relnotes/note.jsp?&im_dbkey=163390&icg_dbkey=825
Is it possible to this in regular Creo? Maybe in 3.0 (I have not upgraded yet)?
Jose
In both Wildfire (1 - 5) and Creo Parametric (1 - 3) color is only transferred from a surface to a solid if that surface has color within the model being cut. Here are three sample scenarios:
Assembly
-- Part A with colored surface
-- Part B
Scenario 1
No color is transferred from Part A to Part B
Scenario 2
Scenario 3
This time the color is transferred from Part A to Part B
I have seen this in Creo 2 with shrinkwrap.
Assembly
-- Part B
Scenario 1
Scenario 2
Scenario 3
Thanks for your explanation.
I checked the feature created by EMX and it's only a simple solidify. They have found a way to transfer the colors through Toollkit code somehow...
However, the scenario 3 you described may be a solution for me.I have to test it.
Thanks for the tip.
Jose.
Good solution
Indeed, actually we implemented the solution described by Tom on scenario 3 and it´s working great.
