I am using Creo 2.0 Parametrics. I have part with several curves that I would like to change to different colors. All I see is how to change the whole part color not indivual feature or surfaces. Can someone help?
Mike
Try using the filter in the lower right hand corner of the screen. You can certainly pick individual surfaces, although some surfaces are "common" although they may have a break in them. Quilts are "surface" features and surface is a solid model surface. Intent Surface is an intelligent filter that accounts for patterned and other "sets" of surfaces.
You can change the properties of curves. This will allow you to assign a color to a curve.
Thank You,
The properties is the way found. I was tring to use rendering to change the curve colors. That does not work with curves. It only work with surfaces and parts.
You are welcome.
