How can I use the "plus" button?
I searched for a specific config.pro's option, but I've not find anything.
The Help gives description for all bar's entities, except for the plus button...
And so...?
The + button will be active when you are in the Annotate tab of the ribbon.
Amit
Amit
Then why in Model Tab can you add combined views through the View Manager?
Anyhoo...thanks
