Combined state in drawing not working.
Visitor
I'd like to add color to the surface of a part in order to make clear that it needs a particular finish. I've created a combined state that shows the surface with color in the orientation I'd like.  When I add that combined state to the model, it looks perfect but only as long as the combined state is active in the model.  Once the default is selected, I still see the view but I don't see any color.  Anyone know why that's happening?  Thanks in advance.
Re: Combined state in drawing not working.
I suggest you to ask PTC Support about requested functionality.
Martin Hanák
I had the same problem with an Assembly. I want also to use the combined state in the drawing for the Color finishing.
I made a call by the PTC Hotline.
The answer is "works to spec"
Regards Matthias
