Config option to allow a gtol to a created dimension?
Newbie
Team,
I can't remember! What is the config.pro option that will allow you to attach a gtol to a created dimension in drawing mode.
ProE gives the error: "You cannot link a part/assembly gtol to a drawing dimension".
8 REPLIES 8
Re: Config option to allow a gtol to a created dimension?
I think the one you may be looking for is:
allow_refs_to_geom_reps_in_drws
It is set to 'NO' by default.
Randy
Hi Greg,
Verify if your config.pro option create_drawing_dims_only is set to NO (default). If it's set to YES, you will not be able to link the gtol to your created dimension so change it to NO.
I often have to toggle that config option since my company policy is to not create dims in the model, only in the drawing.
Patrick
This solution didn't work.
Nope. Didn't help.
If you created your dimension before you made the config. pro switch (create_drawing_dims_only NO), then that dimension is still created in the drawing. Recreate the dimension and try making the gtol again.
Stephen Williams
Pro/E Version 15/16 (Circa 1995/1996)
Check this out
CS17031
I use mapkeys to switch back and forth so I can put a dimension in on the fly and be able to attach a GTOL to it.  Then I can quickly switch back to my default setting and not have to go out into the options area.
We are using Creo 3.
Hope this helps...Brian
Here are the mapkeys:
mapkey ddon @MAPKEY_LABELDrawing Dimensions Only NO;\
mapkey(continued) ~ Select `main_dlg_cur` `appl_casc`;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg` ;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ CellSelect `ribbon_options_dialog` `ConfigLayout.AssyTree` \
mapkey(continued) `node0:create_drawing_dims_only : yes : 3` `ac0`;\
mapkey(continued) ~ Open `ribbon_options_dialog` `ConfigLayout.EditPanel`;\
mapkey(continued) ~ Close `ribbon_options_dialog` `ConfigLayout.EditPanel`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `ConfigLayout.EditPanel` 1 `no *`;\
mapkey(continued) ~ FocusOut `ribbon_options_dialog` `ConfigLayout.EditPanel`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;
mapkey ddoy @MAPKEY_LABELDrawing Dimension Only YES;\
mapkey(continued) `node0:create_drawing_dims_only : no : 3` `ac0`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `ConfigLayout.EditPanel` 1 `yes`;\
Create a datum sketch in the model that represents that dimension; then attach the Gtol to that. Don't poison the model with drawing dimensions.
Preferred approach: redefine the model so the feature is controlled by the dimensioning scheme you want on the drawing.
