Connect 2 faces to create a solid object
Highlighted
Newbie
Hi community people,
I am VERY unfamiliar with 3D drawing tools, so please bear with me...
I am trying to create an object, which "almost" is a 2-D drawing, which must be pulled 30mm.
But the Top/Bottom surfaces are a little bit different.
I have tried to define 2 surfaces "Top"/"Bottom", but I do not know how to combine these and add the missing surfaces.
I have tried to use "Gather Faces" without success
Am I doing it totally wrong?
Best regards
Martin
PS: I am using "CREO Elements Direct".
Highlighted
Re: Connect 2 faces to create a solid object
I actually figured it out myself (after watching 50+ videos).
I created a parallel copy of the workspace, and used Loft...
Highlighted
My first try would be a "blend" feature. I would not bother creating individual surfaces. You define the two sketches at the parallel distance you need.
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
