Copy drawing and model and attach them
SOLVED
Newbie
How do you do this? We tend to make parts off of other parts that are similar so it would come in handy to be able to attach drawings to models. When I tried making a copy of a drawing it still kept it attached to the old model. I tried using add model under legacy migration but it did nothing. Thanks for any help.
1 ACCEPTED SOLUTION
Re: Copy drawing and model and attach them
first, in your config.pro, you need:
rename_drawings_with_object both
With the model open (part or assembly), do:
File>Save As>Save a copy
if you have an assembly open, it will allow you to rename any components of the assembly.
Any objects that are renamed will also create a new drawing, even in the assembly rename
Ken
If the model & drawing have the exact same name, this function is the default. when you copy the drawing to a new name it will make a copy of the model with the same name.
If the model and drawing have different names, it does not work
There are some complicated work around techniques but I recommend that the model & associated drawing have the same name.
ABC.prt ---- ABC.drw
DEF.asm --- DEF.drw
etc.
Dave
Thanks guys. I think you were both correct. With both drawing and part open I renamed and saved them. Renaming the part first. That linked them together.
This was key for my success: Having the part (or assembly) name exactly match the drawing name, this shows your intent to creo in the most direct way.
This is using the file, save-as method within creo (not windchill)
Create parts and assembly, then create drawings that exactly match the drawing name to corresponding prt/asm
ABC.prt ----> ABC.drw
DEF.asm --->DEF.drw
underlying creo config: config.pro, setting: rename_drawings_with_object set to "both"
With the asm model open (DEF.asm in this case), do: File>Save As>Save a copy
rename the asm model and the child part (ABC.prt in this case)
Make sure Associated items > Copy Drawings box is checked
operation results in 4 new items, 1 part, 1 assembly, and 2 drawings
GHI.prt + GHI.drw
JKL.asm + JKL.drw
