Copy sheets from one drawing to another
SOLVED
Highlighted
Regular Member
Is there a way to copy sheets from one drawing to another drawing?
(It's really deleted sheets from an old revision into a newer revision of the same file, but if we need to do it outside of a workspace we've no problem with that.)
1 ACCEPTED SOLUTION
Highlighted
Re: Copy sheets from one drawing to another
On your drawing, in they layout tab, insert drop down arrow, import drawing/data.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Highlighted
Steve Williams
