I would really appreciate if anyone help me to print automatic surface area of model in creo drawing - Either in table or by creating symbol which bring the surface area of the model ?
Thank you.
You can do a search for "Creo use measurement in relation". It will give you the stuff you need to define a parameter that will contain your area measurement. Here's a typical result:
Previous Measure -> Relations Discussion
Once you've defined a parameter, you can use it in a note. I.e. if your parameter is areaModel, in the note text you type "&areaModel" wherever you want to show the value.
if model mass properties are properly calculated then model surface area is available in model parameter named PRO_MP_AREA. To display model surface area in Creo drawing create a note and enter &PRO_MP_AREA text into it.
