Created vs shown dims
This is precisely what I would like to avoid doing if I can. If I can’t, then I can’t. But I was hoping someone had a trick up their sleeve.
Kind regards,
Janet Grove
I don't remember the name, but there is a command you can run that will automatically change all dimensions to be centered in the tolerance range. I believe this is intended to be used prior to export for other downstream suppliers. If I remember right, this centering change is lost the next time the model is regenerated. I'll see if I can find it...
Tom U.
Found it. Dimension Bounds
