I am surprised to see this. I am keen interested to know how would it be possible?
Hi AMARNATH,
Could you please share that part if it is not confidential.
Ketan
Generally, these things (called '2D Views' or 'Draft Views') are made in an import operation, for example by checking the '2D Views' radio button in the IGES import to drawing options dialog. To make them directly is a little more cumbersome: Tools>Applications>Legacy, File>Options>Customize Ribbon>2D View (best found with 'commands not in ribbon') to have a UI control that invokes the command.
They are like regular views in that they have a name+scale, and unlike views in that they have no solid model. They are generally intended for grouping and scaling a collection of draft entities which represent a view (as might be produced by IGES import, for example).
