Creation of "drawing view" using draft entities
Newbie
Hi PRO-E USERS, When i was refering a drawing file i found that the draft entities (say a laptop front view ) were created as a drawing view.It is not having any models.It is having a boundary and if u double click on it, is showing a usual "drawing view" dialog box, where you can actually change the 'VIEW TYPE'& 'SCALE' of the draft entitities and, other options('VISIBLE AREA', 'SECTION', 'view display' etc) are disabled. Generally when we convert a view into draft entities the boundary will go off and we will not be able to get the 'DRAWING VIEW' dialog box. KINDLY SUGGEST ME HOW IT WOULD HAVE BEEN DONE? PLEASE MAKE IT ASAP. THANKS IN ADVANCE.....
RE: Creation of "drawing view" using draft entities
I would like to know about it too...if anyone figure it out... Just guessing its not 2d IDEAS file where you can create the side views by using projection...
