Creo 2.0 Parametric Submenu Tabs disappearing behind main UI
jclingan
Could anyone recommend steps to resolve this issue?
In Creo 2.0 Parametric occasionally (not consistently) while working in the drawing space, i'll select a menu tab in the ribbon which provides submenu tabs at the top of the drawing space and below the main ribbon.
And when I select these submenu tabs, the flyout options dialog that renders as a drop down from that tab goes Behind the main UI so I can't see it or select anyting on it instead of rendering 'on top' of the UI where you can actually see it.
Alt-Tab windows selection lets me see it, but upon selecting it, the main UI is once again on top of it. It doesnt' come to the front.
Once this little glitch kicks in it stays that way until completely closing Creo and relaunching it.
I haven't identified a particular menu selection or keyboard shortcut that triggers the problem.
Hi John,
This could be caused by your graphics card.  Please make sure you are using a certified and/or supported graphics card.  You can check here:
Hardware Notes - Creo 2.0
Amit
