In all previous iterations of Pro-E / Creo, you could create multiple notes without being kicked out of the action. How do we accomplish this in Creo 3.0? We cannot see a way to complete a note without being kicked out of the process and thus having to go up to the ribbon and re-select the action. Between this and the new dimension selection process, they have significantly affected the amount of time required to complete a drawing. I feel like my racecar has the parking brake stuck. It is starting to feel slow and tedious like Inventor.
I don't think that's possible directly.
But Mr. VladimirPalffy from PTCCommunity has developed Repeat Last Command utility for Creo 4.0 to do the same.
http://4kside.com/en/download.html
One user has commented that it works with Creo 2, So I'm guessing it will work with Creo 3.0 as-well.
Just give a try.
