Creo 3.0 Geometric Tolerance window freezes when "select entity" button is pressed
SOLVED
Participant
I am new to Creo 3.0 drawings.
When trying to create a geometric tolerance such as in the screenshot attached, anytime I click on the "select entity" button the "Geometric Tolerance" window stops responding and I cannot select anything in the drawing.  I can click on another button in the ribbon to open a different operation and that will close the "Geometric Tolerance" window and I can continue working.  However, I cannot find a combination of clicks that allows me to create a geometric tolerance.
Any ideas?
Re: Creo 3.0 Geometric Tolerance window freezes when "select entity" button is pressed
At that point, it's asking you to select and axis (that is the default but you can change to axis/surface/edge)
I don't see an axis on your drawing so you don't have anything to select.
Either show the axis you want to make concentric or change the option to surface or edge so you will have something to select.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Steve Williams
