Creo 3 - Select Drawing View
Emerald II
I'm embarrassed to ask this question, but how does one select a drawing view in Creo 3?
I've tried everything I can think of - hold the alt key, change the filter - no luck. I can place a drawing view, but once I do I can't move it, select it, or choose it for "show annotations".'
What am I missing?
8 REPLIES 8
Re: Creo 3 - Select Drawing View
In the drawing tree maybe? Or did they sneak in some more "hold the Ctril key" to select?
Yes, I can right click on it in the drawing tree and select 'properties', but I should be able to select it on the drawing.
I can't get the show annotations to work for ANY dimensions. I'm seriously missing something.
I never had to right click... just left mouse button in the drawing tree on the view and it would bring up whatever I had hilited in the show annotation filter. ... or the LMB of the features in the model tree below it.
Well PTC jumped all over this one. They called me!
The issue seems to come and go. It could clearly be demonstrated when we started the call, but now we can't get it to reoccur. It seems like maybe it has something to do with a config option, but not sure yet. As soon as one of us can figure out the problem I'll repost back to the community.
Minions!
http://2.bp.blogspot.com/-EBS-uaFc2qU/Uc5MgBHghJI/AAAAAAAAC0c/eyqoS4w84vc/s128/851578_213405682141990_401156947_n.png
Right, but in this particular case, the view itself could not be selected. Not with filter, not with select from list. It simply wasn't selectable.
You may want to check the Drawing Tree to make sure you're not dealing with "Overlays". They can't be manipulated like a standard view. You need to call up the Overlay sub-menu from the Layout Tab. I don't use them very often - when I do I leave a bold annotation outside the drawing format to warn the "next" user that they're dealing with a sheet that contains Overlays.
(welcome to the forum, Brad!)
